RCU Forums - View Single Post - Electric glider
Old 11-17-2009 | 05:43 PM
walkermsg
Default RE: Electric glider
Took my new Ventura out and had 3 nice flights. Last flight it nosed into the ground. Not much damage, I noticed when Rudder trim is set full to the right the elevator goes full down when you turn to the right. I reset the trim tab to center and the problem went away. Please be aware this may be a problem, each time I set the rud trim full right the elevator goes to full down when you try to make a right turn. I contacted Tower Hobbies and they are sending me a new transmitter. Hope that cures the problem. Please try this on your Ventura before launch,, may save some crashes.
Lee
