RCU Forums - View Single Post - Throttle Servo Setup
Old 11-18-2009 | 06:55 AM
da Rock
Default RE: Throttle Servo Setup
ORIGINAL: Abv0377
How do i go about setting up a throttle servo so that it gives me the ability to set trim for correct idle on my nitro engine? Today I was trying to increase the idle on the engine and noticed I had the trim on the transmitter at max. What is the proper proceedure to set throttle servos on a nitro/gas engine? thanks for your time and help.
-ABV
A really short answer that covers linkages for all functions is that it's always a good idea to adjust the airplane to remove TX trim found during the model's initial flights.
Adjust the linkage in the same manner it was adjusted while assembling the model.
