RE: Kit Building Cool Tools
OK LOOK OVER ALL REPLIES THIS IS WHAT I THINK AND USE FOR OVER 40 YEARS OF BUILDING RC.. I HAVE A NICE LITTLE SHOP. IT HAS A COMBO OF HARBOR FRIGHT,, DELTA,, CRAFTMAN,, DREMMEL,, M-WARDS,, JC PENNEYS,, AND MUCH MUCH MORE.... I DO HAVE THE SMALL CIR SAW AND BAND SAW AND CUT OFF SAW FROM HARBOR FRIGHT AND AS FOR THE USED THAT I GET OUT THEM THEY ALL HAVE THERE TIME AND PLACE.... IT JUST LIKE IF YOU CUT CHOP A 1\8 WIRE YOU USE THE CHOP SAW AND THEN HIT ON THE BELT SANDER TO DEBUR IT ITS THE SAME WITH THE H.F. SMALL HOBBY TABLE SAW I USE IT ON AIRCRAFT PLYWOOD YOU COULD USE IT ON STICKS AND FORMERS BUT I FIND THAT THE LAST PART OF THE CUT IS NOT AS CLEAN AS I LIKE BUT THERE ARE TIMES THAT IT JUST PLAN AND SIMPLE THE BEST WAY TO CUT OR RIP THAT PIECE OF WOOD AND THEN HIT IT ON BELT SANDER JUST TO CLEAN UP THE EDGE... WITH THIS ALL BEING SAID LET ME JUST SAY THAT THE BEST TOOL IN THE SHOP IS YOU... TO SEE TO FEEL TO LISTEN AND TO THINK... THESE ARE YOUR BEST TOOLS TREAT THEM GOOD
