RCU Forums - View Single Post - Proud Bird Construction Thread
Old 11-18-2009 | 10:10 PM
  #109
sahartman21
Default RE: Proud Bird Construction Thread
After the tail surfaces dry it is time to glue in the elevator horn.
Begin by grinding off any extra epoxy at the joint. Then follow by drilling a hole for access to the horn.
Pin the elevator horn in place and center it so that it is between the sides of the rudder.
Make a dam out of balsa to keep the epoxy out of the hinge line.
Mix some epoxy (Skin-It) and micro-balloons until there is a thick mixture.
Dab the epoxy mix it in place and let dry.
ID:	1316783   Click image for larger version
ID:	1316784   Click image for larger version
ID:	1316785   Click image for larger version
ID:	1316786   Click image for larger version
ID:	1316787   Click image for larger version
ID:	1316788   Click image for larger version
