RE: Q-fuel line source
W.T.M.I. (Way too much information, as my 7yr old would say) I knew you guys were a couple of crayons short of a full box! "Long text messages..." you should put this one up on youtube.
I have also been running the same tubing for the pressure line.
As far as grometts go... I don't use them. I pull the tank to inspect it before the next contest and change the lines at the same time.
If you were to try something, I think the plastic stuff used to dress cable harnesses might do nicely. Ultimately, I don't think it is necessary. But having said that, I will eat my words when the it happens to me.
DK
