RE: Dual Gas Tank Setup
Since you are running a gasser with a Walbro pumper carb, have you considered a single large tank further back in the fuselage? This would help minimize cg shift as the fuel is used also and eliminate the extra plumbing and failure potentials of the dual tank setup. JMHO
