RE: Why does it do it?
After rummaging around the shop last night I found a plastic proctractor to check the timing. It appears to be about 45deg. That would explain the problems. I am going to re-check and set it this evening and run it if I get a chance. It gets dark so darn early here. About 4:45. By the time I get home from work time is short for much work outdoors.
