RE: Nitro Engine help needed badly
angled in yes it makes the car drive strighter or something i forget... but not real wobble thay can be wobble just a little bit becauce there goin to be some play after wear on the rods and hubs if its messing up your stearing then you might wanna change them out... it also could be bearings or shafts in the wheels are bad most likeley not tho... bent rims... could also be from your stearing rod ball caps an balls too... it might be a little bit of all them togather that gives you all the wobble just make sure you know where its comeing from.. my losi xxx-nt has wobble in the front tire ever since i hade it and i replaced everthing on that car more then twice so its up to you if you can drive with the wobble and it dont bother you then dont wory about it... good luck
