RE: Proud Bird Construction Thread
After the micro-balloon epoxy is dry grind the surface flush with a Dremel tool.
Remove the balsa dam at the hinge and use a Zona saw to free the elevator from the horizontal stab.
Check the operation of the control surface. The surface should allow about 1/4" throw each way.
