RCU Forums - View Single Post - Servo problem again.
Old 11-20-2009 | 12:20 AM
Mickstix
Default RE: Servo problem again.
Here ya go! There's really not much to the steering linkage..These should let ya know how everything goes together..Only thing ya cant see very wellis the plasticackerman "arm" that connects the left and right sides.. It has screws that ya get to from underneath, via holes in the chassis.. The only place (in the steering) that may have bb's are the 2 "posts".(servo saver and right side) I've never taken them completelyapart, but they should be pretty self explanitory, with a bb or 2 recessed into the post, that they pivot on.. (If so, make sure your bb's are clean and free.. Slide them down on a sharpened pencil, so the wood holds the inner race, and you can spin the bb and feel how they move. Just make sure they arent froze up, and if they feel gritty ya might want to soak em in some carb cleaner or something, (I put mine in a pill vial with the cap on and some acetone and gently shake em around., then retry em and see if the gritty feel is gone. repeat till they feel smooth, then give em a drip of oil and there ready to go!) Ok, here's the pix..Hope it helps!!
</p>
