RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 11-20-2009 | 09:18 AM
  #304
rctom's Avatar
rctom
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: bgw45
Thanks for the link, AT. I'm not sure why the ''diode'' in the circuit would keep the batter charger from recognizing peek, unless the charge leads are on the board side of the diode and charging would be through the diode.
The diode in a Futaba is there simply to prevent damage to the board if a JR or Spectrum charger was attached. They cause a mess in a Futaba since they have reversed polarity.
In order to detect the peak the charger must be able to sense the voltage of the battery pack. With a diode in there it can not do that.
TF
