RE: Official Venom Creeper Rock Crawler thread..
i'm getting the flm locked diffs from rcbros.com, at 12 bucks each no more compromise. they replace the entire diff.i can run all the motor i want, with less breakage. if you know anyone else that's running a hand wound 35t on a 3 cell lipo then they could tell you about the power, but that kind of power will bring out the weak parts. i found that in crawling most of the power is used by the front axle, so i'm beefing up the front first
