RCU Forums - View Single Post - Heng Long tanks using ball bearings?
Old 11-21-2009 | 08:26 PM
Bagheera's Avatar
Bagheera
Default RE: Heng Long tanks using ball bearings?
Hey
The bearing I used for the gear box are not flanged, 5x11mm Duratrax DTXC 1549. The brass bushings are from the gear box. You need another
set of gear box plates to cut and trim. The brass bushing in the gear box are used to align the 2 new plates together. The new plates are placed
on the out side of the gear box. Clamp the 2 plates together.
Cheers
John
ID:	1318186   Click image for larger version
ID:	1318187   Click image for larger version
ID:	1318188   Click image for larger version
ID:	1318189   Click image for larger version
