Sinse the last post I have had a conversation with one of my friends at our local field and have begun to use the same conversion technique to electric that he used (Thanks, Augie).
I began by cutting away the floor of the front cockpit, I cut from below and used the formers as a guide for cutting. The next istep nvolved cutting away the bulkhead and bottom supports for the fuel tank but being careful not to damage or weaken the main structure. I used a - very - sharp #11 blade to make multiple score lines where the cut needed to be and then breaking away unwanted pieces and finally sanding it all smooth.
Finally, I measured and built the basic structure for the battery box. After I install fences inside to support the 4 - 4 cell Lipo batteries I'll cut
lightning / air circulating holes. The Stearman will be powered by an outrunner 110 with 85 - 100 AMP HV
ESC & 4 Lipos - 2 in series for 8 cells to give the power a 15 lb plane will need and 2 in parallel for some descent flying time.
Glynn
<fieldset><legend accesskey="I">Attachments</legend><table width="10" cellspacing="0" cellpadding="2" border="0"> <tbody> <tr> <td><a onclick="return hs.expand(this, { slideshowGroup: '9270969', align: 'center' })" class="highslide" href="http://image2-3.rcuniverse.com/e1/forum/upfiles/490928/Tq48933.jpg" style="">
<font size="1">Click for fullsize</font></a></td> <td><a onclick="return hs.expand(this, { slideshowGroup: '9270969', align: 'center' })" class="highslide" href="http://image2-5.rcuniverse.com/e1/forum/upfiles/490928/Bw73425.jpg" style="">
<font size="1">Click for fullsize</font></a></td> <td><a onclick="return hs.expand(this, { slideshowGroup: '9270969', align: 'center' })" class="highslide" href="http://image2-5.rcuniverse.com/e1/forum/upfiles/490928/Xc78595.jpg" style="">
<font size="1">Click for fullsize</font></a></td> <td><a onclick="return hs.expand(this, { slideshowGroup: '9270969', align: 'center' })" class="highslide" href="http://image2-8.rcuniverse.com/e1/forum/upfiles/490928/Cw63988.jpg" style="">
<font size="1">Click for fullsize</font></a></td> </tr> <tr> <td>
</td> </tr> </tbody></table></fieldset>
