ORIGINAL: Fla.Ryder
ok i was lookin at the himoto web site and found this
http://server.sohouniverse.net/~himo...;=SID#MOREINFO this is the diff shell to the left of the diff shell what is that is that a seal/spacer/washer or something of that sort??? if so that might be why it is binding i didnt see any seals on any of the front or back diffs.. and i also have a few other things to ask.... on the torpeda can i put Stabilizer Bars in the front too?? it came with one on the back but i seen the the spot for one in the front.. and what the diffrence in the clutch shoes what so good about haveing Metal Clutch-3pcs vs the standerd ones?? and the three pins that the clutch shoes sit on do i need a new flywheel is thay broke off?
Iwill wait for Randy or someone to get back to you about the diff shell, I NEVER took mine apart on my torpeda's, it should have come with a stabilizer bar in the front. a metal shoe will grab faster than the nylon shoes but they do need maintaince. You will need a new flywheel, that is part of the flywheel.
