RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Let me add ONE additional enthusiastic comment....this thing links FAST. Once it is married up, the system doesn't seem to care if you go RX off first, or not, and the signal is there NOW.
There is also NOdiscernible lag between servos... on my Ultimate, the elevators track VERY well, and running in the "TEST" mode using the TX to control it, you can watch each step....it is really very surprising.
Then, there is the "speed" at center....holy mackeral....the video somewhere of someone letting go of the stick, and the servos following the "boing" of the spring going to center is absolutely true.
One last thing....power consumption.... I used 1100 mah for 7 hours and 36 minutes of "power up" transmitting time. That's average "full power" current draw of 146 ma. Ain't much....
