RCU Forums - View Single Post - Why does it do it?
Old 11-22-2009 | 02:42 AM
Tired Old Man
Default RE: Why does it do it?
The slot thing troubles me. Seems that every Chinese engine manufacturer does one of two things wrong on their engines. The first is failing to use the right math to determine the correct location for the timing magnet. The second is to use a sensor bracket with adjustment slots much too short to achieve the correct timing. There's also a third. Failing to establish the correct hole positions for the sensor bracket screws.
