RCU Forums - View Single Post - Aerotrend coupler material replacement?
Old 11-22-2009 | 11:30 AM
MTK
Default RE: Aerotrend coupler material replacement?
ORIGINAL: cd3217
I understand that there really is no more Aerotrend.... Has anyone found a source for the same type of material?
I'm using a McMaster Carr coupler material
McMaster Number = 5236K951
(Same as 5236K95)
Silicone Rubber Tubing Soft, 3/4'' ID, 1'' OD, 1/8'' Wall, Blue
Quantity Per Ft.
1-99 Ft. $3.43
I don't believe this to be nearly as robust as the Aerotrend stuff I used to buy as exhaust extensions so if anyone knows the Aerotrend source can you share the info
Thank you,
Chris
I have been using a thin fiberglass-teflon laminate with silicone adhesive. I simply roll a coupler out of this stuff, directly onto pipe and header, adhesive side down. Purchased from Mc Master Carr. High strength, hi temp and needs no clamps. Also very light since I only need about 5-6 layers.
http://www.mcmaster.com/#fiberglass-tape/=4m5eoo
MattK
