Global Ultimate thrust angles???
That is great information, thanx. I’ll start flying it without the cowl and make any necessary adjustments then. About the aileron servos, I’ve just enlarged the standard mounting hole so that it can hold two standard servos mounted side by side. Now about the nose weight I’ll see how it goes and if everything moved forward and weight still needed, I’ll go for the ST 90
Regards
George C
