RE: Dual Airlerons
ok, heres what I've done
I've tryed every combo I can to make both servos work off of C-1..no go..only one servo on the 2 to 1 harness would work...the left A.servo..couldn't get both together..I thought the new non-working futaba 3004 was bad...I checked it independently and it works...I could make the right A.servo work when I reversed the plug into the harness..then the other servo would not work..
Finally, I abandoned C-1 went to C-6 with the 2 to 1 harness and enabled the swtich on the tranmitter for flaperon..its works..but I have buddies at the field saying I shouldn't get the flaperon and airlerons mixed up..I don't have flaps ..I dunno
so C-1 in the receiver is empty
C-2 is elevator
C-3 is throttle
C-4 is rudder
C-5 is retracts
C-6 is a 2 into 1 harnessed airleron..I guess..there working
