ORIGINAL: KeithjV
35-35 might work for you. If you are doing big jumps heavier will give some extra damping to soak up the landings.
How did you get the 17T clutch bell in? Did you widen the mounting holes?
Thanks i will try some 35 weight oil.I didnt have to mod anything to get the 17 cb in.There is enough room to get an 18 in before i need to mod anything.
