RCU Forums - View Single Post - UAT question
Thread: UAT question
Old 11-23-2009 | 07:32 PM
ravill's Avatar
ravill
Default RE: UAT question
Well, if you are certainly flying "more aggressive", that could certainly explain your findings.
To be safe, run up your fuel pump at the voltage that it usually see's at full throttle for the entire fuel capacity and see if the UAT sucks in air or causes cavitation.
If you see air on the ground runs, you have a problem. If you don't see air, then it's your flying!
Raf
