ORIGINAL: randy10926
The web site lists different versions based on the length from the firewall to the prop hub. They list four different lengths. 5.2 inch is the shortest distance from firewall to prop hub.
Randy
I am not certain of the absolute minimum length. To retro fit my existing firewall I cut the stand offs a bit to just clear the choke baffle. Choke baffle articulation is the limiting factor for length for all practical purposes.
I have approximately 1 mm clearance between the soft mount and the baffle. There is a portion of the carb that actually resides inside the central cutout of the mount. I also opened a hole in my firewall such that the engine actually breathes from the fuselage. It wasn't necessary since there is plenty of clearance around the mount central opening but I did it to help in the quietness department. It helps quiet the intake. It's a technique I will carry forward to other set-ups
MattK
