RCU Forums - View Single Post - GSP Katana
Thread: GSP Katana
Old 07-06-2003 | 02:31 PM
elmerfud
Default stuff
well. good to hear it pulled fuel from tank from where you had tank....i was going to try that but i was worried this twin does not even use a pressure nipple.(so they tell me) so i kept tank in front to give it all the help i could..
and yes i thought about moving rudder servo......1.9 oz in the back seems like a lot. i guess if and when i get close.. if its tail heavy i could just remove servo (in rear) to see how things end up(balance). but i do not look forward to moving it ....if i need to..
i crack up every time i hear "ARF" should be MORE LIKE "BETTER THEN BUYING A BOX OF WOOD" heh...
the little ARF`S .40-.60 are easy. but this big ones i spend some time on it seems
i will keep you posted on how it does.... this is my first "twin" as well
thanks for input
