ORIGINAL: risky
What type of monocote did you use?? The regular monocote or a low temp?? and no problem's with the foam melting??
Ultra kote hanger 9 ??. Set iron to 1/2 the dail setting...TEST THE FOAM INSIDE OF THE CANOPY USING THE COVERING. Start like on setting 2.... then work up on temp.
Use as low a temp. as you can to get the foam to stick to the foam. I don't wrap the wing...I cut to fit the top of the wing then add a front cover..either tape or more covering.
Take your time and exp. don't use to much temp.
Cp
