inside
yes it fits inside.... all of it... i will get some photo`s of front.... carb inlet sticks out a bit under prop....... but if i did it again i would extend firewall(boxed area) another little ways......i extened it about 7.5 - 8 mm then shortened the cowl a little.
i need to do something with exhaust ,,,, has short little header pipes...may put holes in the sides(of cowl) and exit them even with sides like an ole warplane..... not sure.
then after reading some posts here ...i may have a siphon issue....tank is a bit higher then i wanted in relation to carb inlet...
i will do my best to keep things posted on here.
