FT-120
well cool.....i tried inverting one i have... just wont work out with cowl.... and exhaust . and carb inlet.... not practical..... i will have to see if it floods.... then if so......go from there. i could use a perry style pump.... it would act like an anti-siphon..(just an idea)moving the tank.....would be quite an undertaking in this plane......not to user friendly through access hole
i am curious on props i have a 16x6 and a 16x8. i was going to try...(remember mine is a 120 not a 160..<older,new in box..,but older . now they are 160`s)
maybe you could ask your friend or let me know if the 120 could take the same prop...or should i stick to the 16x6 or 16x8....(try them).......or just bump up to the 18x6
i thank you for all the input
chris
