Throttle servo
I mounted mine in the fuse last night, I origionally had it mounted under the engine box on the firewall using the two piece wood frame they give you. It worked fine but it did get covered with exhaust oil. In that location I don't know how long it would have lasted. It was very easy to mount in the fuse, I probably should have done that to start with.
