RE: Spad to the Bone Dominator Problem
I took out the downthrust, moved the landing foward 1" and retrimed the ailerons and it flew better but still real squirley. I decided to build a new fuse that is 7" longer and use the same wing and tailfeathers. CG and wing placement is moved to be the same ratio as the orgional. Will see what this does.
