RE: Great Planes Reactor GP/EP 3D ARF .46-.70
The OSFS91 is 24.2oz. However, it is definately lighter than the 75AX being suggested. Alternatively, I could use a 55AX but I am not sure it will work well at 45Deg off from inverted. I fly at sea-level so power isint an issue. However, I have no access to the Saitos. I will be using a 14x4 or 15x4 MAS. Battery will be 6cell NiCd. Servos will probably be Futaba 3010s on all surfaces. There will be a 6004HS 2.4 Ghz RX that I am saving up for this plane with a 2.4G module on my 9CAP.
Ameya
