RCU Forums - View Single Post - Removing and assembling (maybe)
Old 11-25-2009 | 05:39 PM
yadac123
Default RE: Removing and assembling (maybe)
look into the main shaft, remove the set screw under the swash plate then remove the screw that locks the main gear into the main shaft. Finally remove the set screw at the bottom of the main shaft and your entire rotor head can slide out.
Andy
