RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-26-2009 | 07:46 PM
  #1394
lodomjr
Default RE: Black Magic VF3 Build Thread
Chris,
My hard points are set the same way Arch described. I noticed your bevel line passing right through the bolt hole, you may want to reset the bevel amount you are putting in the ailerons. Maybe let the bevel line pass in front of the bolt hole about a 1/16th inch. This will shorten your aileron deflection a little, but you don't need a tremendous of aileron deflection anyway. As Arch said that you will sand into the hard point some making the bevel but it's ok. I also use the 6x32 bolts for control arms and the MK style adjusters. I use small 6x32 blind nut put on upside down with the barbs removed as jam nuts. This set up makes for a good solid control arm assembly.
Larry
ID:	1321197   Click image for larger version
ID:	1321198   Click image for larger version
