The idea sounds like fun, but I think you are jumping the gun just a little bit. Your biplane will need to be a 4 channel so I think you should at least get some 4 channel experience on another plane before trying to fly a biplane. Also you should have tail dragger experience. Is the trainer you are flying a tail dragger or a trike plane? Since you have a puter then why not download the free FMS flight sim and try some taildraggers? Pick a Corsair and see how you make out. IF you don't add in full up elevator before hitting the throttle, the plane will immediatly nose over into the ground! The plane flys ok if you can getr it off the ground however. Havew fun, Fast!
