RE: JetCat P70 Strip
I'm stipping down an older P-120 due to bearing noise and I have a small problem...The rear bearing didn't come out as an entire unit...When I removed the shaft with the turbine wheel the outer bearing race remained in the bearing tunnel and, of course, the inner race remained on the shaft...
How do I remove the outer race from the shaft tunnel???...It is in there pretty tight...
Kevin
