RE: Please help me do the unthinkable ...
See if you can find an US. Aircore kit. They are the best planes to learn on very durable..........Flight Sim is a must.. Try to keep making left turns fist, you will not get as much P-Factor and you will not have to use the rudder to keep the nose up in your turns and much as you do on right turns, always remember to put the stick to the low wing if the plane is coming at you... This will help you level in flight....
Good Luck
