ORIGINAL: ro347
Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage?
ro347......i told you everybody would chime in here after they were done "power napping" from eating all that good turkey stuff......by the way, a q-tip work's good, so does an epoxy brush, i use the epoxy method, the bristle's get in to those crevises pretty good.....when i reassemble my motor, i sometimes use 3-in-one oil, because my other hobby is boat upholstery, i alway's tend to have some 3-in-one laying around, i use the 3-in-one to lube my commercial sewing machine,too.....good luck with the motor.....KOOLKRABBER47......
