RCU Forums - View Single Post - Getting engine back in service.
Old 11-28-2009 | 05:54 PM
ro347
My Feedback: (13)
Default RE: Getting engine back in service.
ORIGINAL: koolkrabber47
ORIGINAL: ro347
Thanks for the support guys. One more question: Once I remove the rust, what should I be coating the engine parts with during the rebuild stage?
ro347......i told you everybody would chime in here after they were done ''power napping'' from eating all that good turkey stuff......by the way, a q-tip work's good, so does an epoxy brush, i use the epoxy method, the bristle's get in to those crevises pretty good.....when i reassemble my motor, i sometimes use 3-in-one oil, because my other hobby is boat upholstery, i alway's tend to have some 3-in-one laying around, i use the 3-in-one to lube my commercial sewing machine,too.....good luck with the motor.....KOOLKRABBER47......
Thanks Kool!!! Just got back from Lowes and picked up an 8oz bottle of Air tool oil for about 2.50 and a couple of dremel polishing brushes. The bearings are on the way. So this should work out just fine. thanks again!
By the way....how do you like the power of your 46AX on your PA Bad boy with the 12x4? Im basically doing the same setup on an OMP ProYak.
