RCU Forums - View Single Post - Servo mounting tips needed
Old 11-28-2009 | 08:46 PM
SeamusG's Avatar
SeamusG
Default RE: Servo mounting tips needed
ORIGINAL: Hello82
also I try to avoid the"wood screw" type and use "sheet metal" type servo screws....wood screws are usually triangular shape all the way down to a point...meaning once/if it loosens just a bit, I will get looser even quicker because of the triangular shape...while sheet metal screws are more parallel all the the to the point , so there will always be consistent friction against the threads
Good to know - thx.
