RCU Forums - View Single Post - Getting engine back in service.
Old 11-29-2009 | 04:17 PM
ro347
My Feedback: (13)
Default RE: Getting engine back in service.
ORIGINAL: koolkrabber47
ORIGINAL: ro347
ORIGINAL: ro347
Got it all cleaned up...now a little heat to dry up any moisture. Question: Only 1 part left if I can figure this out - How do I get the connecting rod pin out of the cylinder. I pulled out the little clips in the cylinder, but cant get the pin to slide out. Tried tapping it, nothin!!!! Any ideas?
I GOT IT - placed it in the oven at 200 for 20 minutes and it popped right out.
ro347......you see, even an old fart, with year's of flying, can learn new trick's......i never knew how to take a motor apart like you just did.....i've alway's ran quality o.s. product's and alway's the higher-end, better performing sf-fx-ax stuff.....that and the fact that i alway's run my fuel out and add after-run oil before i put my planes up, i've never had an engine rust or gum-up or lock-up......i've still got a couple of o.s. motor's that i've been flying for well over 15 year's, i think each one of them have been in 6-7 different planes over the year's.....kinda say's something about the after-run oil debate???.....it's all a matter of preference/opinion when it come's to after-run oil.....now if i ever do need to tear a motor apart, it won't be a problem, thanx to this thread......KOOLKRABBER47.......
2 Strokes are pretty simple. Its nice to take one apart even if you dont need to just to understadn how they work a little better.
How is the pull out from a hover with the 46AX on the Bad Boy,,,,strong or does it struggle?
