RCU Forums - View Single Post - Engine not sucking fuel
Old 11-29-2009 | 09:26 PM
crbhawking
Default RE: Engine not sucking fuel
ok so the tubing is fine, in fact i took it all out of the plane to run the tests. no blockage in the fuel lines as i could easily blow fuel through them, however when attached to the carb with the needle valve at 3-4 turns and throttle open there was still trouble blowing fuel through.
