RCU Forums - View Single Post - GP Extra 300 .60 question
Old 07-06-2003 | 02:35 AM
PDF
Default GP Extra 300 .60 question
Hello,
I was reading through my instruction manual prior to starting. Regarding framing and sheeting of the Fin, it requires a 3/16 x 3/16 ( bottom key ) glued to the bottom of the fin which goes from the fin post to about 1/2" before the leading edge of the fin. I would assume when you sheet this you sheet the whole fin and post, but when I look at the picture in the manual it shows the bottom of sheeting flush with the bottom of the fin (less the bottom key) is this correct or do I sheet everything.
Thanks in advance,
Pat
