Kyosho Super Stearman
I have about 100 flights on mine so far... Stab is fine.. I'm overpowering it with a Saito .72 mostly at full throttle too so I'm probably putting more wear and tear on mine compaired to others.. It's the strongest ARF I've owned.. It will take a beating really well.. The only modification I've done, is re-inforce the wheel pants with fibreglass to make them more rigided. It required to extra weight to ballance with a Saito .72 (Battery is on CG). It flies really well, and it can fly VERY slowly without stalling.. It floats like a ******* comming in for a landing.. You'll need FULL UP ELEVATOR once it's on the ground to prevent it from nosing over so the ground handling isn't that great (Or field is grass).
It's definitely a keeper and if anything ever happens to it, I'm immediatly ordering another one.
Adrian
