UAT to fuel pump fitting
ok, I have read that some people tend not to use any festos on the UAT to fuel pump side. If that is true, how do you reduce the tubing down to fit the fuel pump barb?
Right now I have a Hanson UAT with a festo connector on it. It takes 1/4" OD tubing. Is there another way to reduce the tubing so it will fit on the fuel pump?
