RCU Forums - View Single Post - Neptuno 170
Thread: Neptuno 170
Old 12-01-2009 | 02:08 AM
riot3d
Default RE: Neptuno 170
Some specifications:-
Length: 1,990 mm
Wing span: 1,870 mm
Wing area: 66.4 dm square
Stab area: 16.5 dm square
My plane:-
Fuse: 1,240 g
Wing: 920 g
Left stab: 130 g
Right stab with stab tube: 140 g
Left gear: 60 g
Right gear: 60 g
Wheel pants: 20/20 g
Equipment:-
Futaba 14MZ
Rx: R6008HS
Battery: 4.8v, 2,000 mAh nimh
Ail: BLS 154 x 2
Ele: BLS 153 x 2
Rud: S9156
Thr: S9650
Engine: YS 170 cdi
Header: Hatori # 822 or # 823
Pipe: Hatori # 821
Pipe mount: Nishioka 29 or 37 mm
Tank: K&S 600 cc
Spinner: TY1 plastic spinner
First order of business is installing ail servos. Since servo horns, rod ends and turnbuckle push rods are all included, installation is a breeze. Don't forget to glue a small piece of foam inside the ail servo leads opening, so the leads will not accidentally drop inside the wing. Next step , tail wheel, ele servo installation.
ID:	1324112   Click image for larger version
ID:	1324113   Click image for larger version
ID:	1324114   Click image for larger version
ID:	1324115   Click image for larger version
