Field Box Contents
I've been really into this for a few years now...This is what I have in mine.
Stuff for maintenance and repair-
Big and little screw drivers of every type
A whole set of those tiny screw drivers
Set of metric AND standard allen wrenches
A couple self-tapping screws just in case
Tape
Pliers (that how you spell it?) needle nose and some big ones
4 way wrench for the glow plug and prop nut
Extra prop nuts
Extra props
Extra glow plugs
Extra wheel collars
Extra fuel tubing
CA glue (never hurts to be prepared!)
As far as stuff you need to fly-
The glow igniter
Chicken stick for starting
Fuel
Fuel pump
Transmitter!
That's all I can think of right now...Did I miss anything? I've got a few more things in mine like a field charger, 12 volt battery, volt meter, tachometer, an extra muffler, and some other stuff. Until you feel the need for it all, I'm sure you can barrow that type of thing from other guys at the field. I know I wouldn't mind...
You might notice I didn't mention a starter. I don't use a starter and never have...I think it's worthless weight!
