RCU Forums - View Single Post - Engine not sucking fuel
Old 12-01-2009 | 08:54 AM
psuguru
Default RE: Engine not sucking fuel
ORIGINAL: frugalflyer
Check inside the tank.
Amen.
I quite regularly get cracks in the clunk tube.
crbhawking
Instead of sucking the fuel, try putting your finger over the end of the silencer and allowing exhaust pressure to blow it through.
If that doesn't work then there's a hole or blockage (fuel filter?).
Do you filter your fuel as you're filling too?
