RCU Forums - View Single Post - Need quick answer - correct powerswitch wiring?
Old 12-01-2009 | 03:35 PM
taoJ
Default RE: Need quick answer - correct powerswitch wiring?
Looks correct to me, all your doingis interupting positive voltage , a simple meter test should show you open and closed positons, if you have those then your good to go, if you dont have a meter, hook up your batt and a motor to the output side of the switch and see if you can control the motor on/off via the switch.
