RE: Typical Building Times..
I am with ram on this one. I am somewhat of a perfectionist so I reinforce where needed, address covering issues, use other type hinges than CA, make sure everything is square and if not, adjust as needed, etc. Overall, it takes me longer to assemble than indicated, but that's the way I build. If you just put it together as ram mentioned, I am sure you can do it pretty fast. The exception would be Nitroplanes ARFs, at least the one that I have experience with: they take a while!
