RCU Forums - View Single Post - First 4-stroke engine. Help?
Old 12-02-2009 | 08:02 AM
  #32
Insanemoondoggie's Avatar
Insanemoondoggie
Default RE: First 4-stroke engine. Help?
I have used all tips mentioned above, and they all work. Main thing I have come to notice is don't expect a lot till you get a gallon or 2 thru any four strokes. I do recommend you run a 10% nitro ,castor/syn, blend with at lest 18% oil . Break in as Magnum manual recommends .
ASP/Magnum weak spot is a sloppy fitting HS needle , I used largefuel tubing on a coupleand it has do the trick nicely.
