RCU Forums - View Single Post - SET UP
Thread: SET UP
Old 12-02-2009 | 09:47 AM
rrritchey
Default RE: SET UP
Hi Henry,
You will have to make a Deans UltraPlug to JR plug adapter for the SuperReg. The problem with this setup is that you really need 1 connection from the regulator for every 2 servos so you really need about 4 connections into the receiver from the regulator to support running servos off your receiver which you are not going to be able to do with a 7-channel receiver. I would recommend at least 2 connections from the regulator to the receiver. The Eq6T warning does not apply here because you are not taping the servo outputs. From the SuperReg you can plug into the battery port and an open servo port on the receiver.
